March 16, 2015, 23:10 |
multiple outlets-boundary conditions?
Rep Power: 13 |
I am modelling an aircooled chiller, just interested in air velocities, not heat exchange. I got 3 domains: surrounding air. 6 porous domains in a pattern. These are in 3 V-blocks with 2 outlets each. This gets me 3 domains with boundary to the porous domains. The porous domains (radiators with pressure drop about 90Pa at 3m/s) then have boundaries to the surrounding air. Now the problem: surrounding air is entrainment inlet. The outlets I set as 6 different outlets, each 9kg/s mass flow. The results are pressure drops of 70kPa, this would mean there is a near vacuum inside the vee-blocks. In reality its not, I would expect a few Pa pressure drop. The only answer I found to multiple outlets, set them as 1 outlet. Can post a picture later Cheers, Steffen Last edited by Steffen595; March 17, 2015 at 04:20. |
March 17, 2015, 05:38 |
Rep Power: 13 |
its only about 80Pa across the coils, thats the section, where the craph goes down a little. I first simulated the pad on its own to get the porosity settings right
March 17, 2015, 06:13 |
Rep Power: 13 |
I just modeled a block on top to connect the 6 outlets to one, see if that helps. Just using one of the 6 outlets still gets 60kPa pressure drop, not nice. And it drags air through the whole thing. Unfortunately I need to see what happens between the vee blocks. Its a bit of an ask for the software.
Edit: seems to work now. Part of the problem was maybe, the inner bits of the vees, with the outlets, were a 2 bodies. With the block on top now its 1 body. Last edited by Steffen595; March 17, 2015 at 07:29. |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 09:49 |
ribbed channel / simpleFoam / boundary conditions | beeo | OpenFOAM Pre-Processing | 20 | July 17, 2013 08:39 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Multiple Velocity Boundary Conditions? | eishinsnsayshin | Main CFD Forum | 0 | July 28, 2011 09:55 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 18:29 |
