May 4, 2015, 22:02 |
How to set two phase flow
Rep Power: 11 |
Hi all
I'm using ansys 15 I'm using fluent Two phase flow water and air I set phase 1 water Phase 2 air But there is no option to set deferent velocity for each phase Just velocity for the mixture fluid Can any one help me How to set deferent velocity for each phase |
May 5, 2015, 10:36 |
Henry Arrigo
Rep Power: 15 |
I think you should determine which module you are going to use beforehand, e.g FLUENT/CFX. Then you would be able to find relevant tutorial in their documentation.
May 12, 2015, 20:48 |
Rep Power: 11 |
Thanx a lot for your replay
I'm using fluent |
Display Modes | |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 18:02 |
Three Phase flow into a reservoir... | akjha | Main CFD Forum | 0 | December 15, 2014 08:01 |
Divergence in Two phase flow in impeller for Cavitation | joshghoun | Fluent Multiphase | 2 | November 5, 2014 10:33 |
How to set phase dependent turbulence models? | J.Yang | CFX | 2 | August 29, 2002 16:39 |
