Grid In-dependency question
Old   March 14, 2016, 06:02
Default Grid In-dependency question
Alia Amer
Alia Amer is on a distinguished road
HI ALL!!
I am new in this forum and i have a question.... i am using FLOTRAN module of ANSYS 12.0 inorder to study ventilation performance inside hospital wards. my question is regarding the grid independency... can any one give me a simple explanation on what does it mean and how to do it.... Thanks in advance!
Alia Amer is offline   Reply With Quote
Old   March 14, 2016, 08:16
fresty is on a distinguished road
Hard to believe you couldn't find it in the forum or elsewhere.. anyway, probably the simplest descriptive explanation could be: to reduce the mesh element size (increase grid density) till the solution is independent of further grid resolution... however, it depends on what exactly is the objective of the simulation and the level of accuracy required, both set forth by the user... normally the values of desired variables are compared statistically with previous/ next/ mean/ initial values and the solution is termed grid independent once percentage deviation/ difference is sufficiently reduced..
fresty is offline   Reply With Quote
ansys flotran grid
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 10:08
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
Moving Body Grid Question Matt Main CFD Forum 5 September 13, 2004 00:45
