Home > Forums > ANSYS
Running Ansys fluent fom terminal (no GUI)
Old   May 20, 2016, 06:23
Default Running Ansys fluent fom terminal (no GUI)
mahmoodn is on a distinguished road
As a cluster administrator, I am trying to help the users to run their ANSYS fluent command from the command prompt (aka terminal) in a text only cluster.
There is a .cas and .dat file and i want to set the number of processors (for parallel execution) and then run the application.
A user showed me from the workbench that the solver is set to Fluent and he right clicked on "setup". There, he set the number of processes and then he chose "solution" and I saw the Fluent window. He then ran "Calculate".
What are the commands for such steps? The Ansys is 17.0
Please see the pictures for Setup and Solution
mahmoodn is offline   Reply With Quote
Thread Tools
Trackbacks are On
negative cell volume detected while running ANSYS Fluent UDF khushbu.bhavsar92 FLUENT 0 March 27, 2016 22:45
Can you help me with a problem in ansys static structural solver? sourabh.porwal Structural Mechanics 0 March 27, 2016 17:07
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Results are different for Ansys Fluent 14.0 and Fluent 6.3 syavash Fluent UDF and Scheme Programming 1 February 17, 2013 02:09
ERROR while running ANSYS FLUENT on CentOS_ HELP NEEDED juzer_700 FLUENT 0 January 21, 2013 01:51
