Computation of Radial Thrust/Torque Loading
Old   October 4, 2021, 10:33
Default Computation of Radial Thrust/Torque Loading
Daaman is on a distinguished road
This might be a pretty basic question, but I'm unable to wrap my head around it. I want to calculate the radial thrust and torque loading on the propeller blade using the CFD results from ANSYS Fluent & SU2. The sectional thrust and torque of a twisted propeller blade are a function of - the local angle of attack, local lift, and drag. I can extract the pressure distribution at each spanwise element section and integrate them to compute the local lift at each section. But, for calculating the sectional drag I require the element thickness (airfoil) at the given span, which I don't have. My question is, how can I extract the thickness of the element at a span (for local drag) and the local angle of attack (for final thrust and torque) from the Fluent/SU2 data? For the moment, I am ignoring frictional forces.
Thanks!
Daaman is offline   Reply With Quote
[swak4Foam] difficulties installing swak4foam newbie29 OpenFOAM Community Contributions 120 October 21, 2022 04:01
Identifying Markers in a CGNS Mesh tjim SU2 3 October 12, 2018 01:21
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 05:28
Computation through radial impeller Ursenbacher Main CFD Forum 5 January 12, 2000 01:27
3D Computation through a radial impeller Ursenbacher Main CFD Forum 3 December 15, 1999 19:56
