ICEM HDF Connectivity
Old   June 30, 2009, 18:04
Default ICEM HDF Connectivity
Glockenspiel is on a distinguished road
Hello All,
I've been given a simple, 5 block, structured mesh of a cylinder generated in ICEM and exported in the HDF5 format. Unfortunately, it seems that the transformation vector given in the ICEM-generated HDF5 file is not consistent with the SIDS-CGNS standard. Would anyone happen to know what the relationship of the <Constant Index, First Index, Second Index> to the SIDS connectivity standard is for structured meshes?
Thanks
-Glockenspiel
Glockenspiel is offline   Reply With Quote
Old   July 1, 2009, 23:43
Thought I'd update this for anyone else that might encounter the problem. The ICEM generated <Constant Index, First Index, Second Index> for the current block patch correspond (more or less) to the index locations of the standard SIDS transformation vector. The donor patch <Constant Index, First Index, Second Index> values are then substituted into the transformation vector.
I.E.
My Block Vector
<1,2,3> (these are you index values)
Donor Block Vector
<3,1,2>
...substituting the first value yields:
<3,_,_>
the second:
<3,1,_>
finally:
<3,1,2>
Of course, you'll need to program in some sort of logic to consider the bounds of the abutting faces (i.e. a i-low abutting against a k-low face) and for the case where you might have a negative value in one of the block indices indicating the start/end nodal locations differ between the blocks.
At any rate, I hope this can help someone...if clarification is needed just post a reply and I'll do my best to assist.
ICEM BC to FLUENT Simon CFX 3 September 9, 2008 17:08
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 03:39
re: ICEM vs. ICEM WB Wooster CFX 4 October 15, 2007 12:47
ICEM 10 mesh scale foe CFX Korsh Mik CFX 2 October 7, 2005 09:07
ICEM CFD 5.1 Hex-Tet mesh merging failure bogesz CFX 1 January 29, 2005 06:46
