Particle Momentum Source
Old   November 9, 2009, 12:04
Question Particle Momentum Source
Zach
Tommie2009 is on a distinguished road
Hello Everyone,
I am working on a simulation involving small solid-phase particles (0-3 micron) and relatively low concentration (1%) traveling through a fluid. I am also using the particle collision option in CFX. I am curious how the program calculates the values for the variable "Particle.Particle Momentum Source." Does it only take into account interactions between the particles, or is it also affected by impacts with the wall?
Ultimately, I'm curious if there is any way to quantify the magnitude of particle-particle collisions in the model. Any other insight would be greatly appreciated!
Thanks,
Zach
Tommie2009 is offline   Reply With Quote
Problem with Mass source, Momentum source theory diffo Fluent UDF and Scheme Programming 0 August 20, 2009 06:10
Particle momentum source alvio CFX 0 August 20, 2008 16:52
User Fortran and Particle momentum source alvio CFX 0 July 30, 2008 22:52
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
