-   ANSYS (http://www.cfd-online.com/Forums/ansys/)
-   -   Bearing 3D FEM model....help!!! (http://www.cfd-online.com/Forums/ansys/68889-bearing-3d-fem-model-help.html)
hydrogenum October 5, 2009 11:28
i'm a new user and i have a problem...
...i'm modelling a 3D roller bearing in Ansys and i've follow these steps:
-definition of the geometry (shaft+inner ring+rollers+outer ring).
-setting of material and elements type.
-mesh all components.
-apply contact elements between shaft-inner ring, rollers-inner ring, rollers-outer ring by Contact wizard GUI.
-apply DOFs (ALL) on the trasversal shaft's surfaces.
-apply surface load on outer ring
...now the problem is...there're not a cage so....how to constraint the rollers? (30 rollers).....how i can to simulate the bearing's cage?
...i think there is a function to set a constant distance between rollers...can i use a Constraint Equantion?
....help me,please?.....
L.
