October 29, 2009, 08:44 |
Fatal Error - Ansys (Workbench)
Andrew High
Hi , I am using the 12.0 version, Vista 32 bit. When I try to run the Workbench I only get error message: "system.nullreferenceexception object reference not set to an instance of an object. in Ans.UI.SplashScreen.ReturnError(String image Path) ..... " . ICEM and CFX Launcher are working properly. Does someone know where could be problem ?
February 4, 2010, 09:43 |
#2 | |
Jon Powell
Did you find the cause of the problem? Can you now successfully install on Vista? |
February 15, 2010, 03:53 |
Chebeba
This error can be caused by running an OpenGL graphics driver which is not compatible with your current Ansys version. With 12.0 I fixed it by downgrading to an eralier version of my graphics driver.
However myself I am now also getting it with 12.1 with the officially certified driver as soon as I try to open the Engineering Toolbox window.... |
February 15, 2010, 04:05 |
Jon Powell
We've given up with Vista, luckily our installations for Ansys 12.1 are now only done on machines with XP. I presume Windows 7 can only be better than Vista.....
February 15, 2010, 09:09 |
Chebeba
I was able to fix the problem.
The page at http://ati.amd.com/products/workstat...erators.html#2 lists 8.634 as the most recent certified release for Ansys 12, but it didn't work. I donwgraded to the older certified release 8.543.1.3 and the problem went away! Very sensitive to OpenGL version obviously... |
January 16, 2014, 10:49 |
Ansys fatal error
Wael sghaier
I'm a beginner of using Ansys software, please how could I fix this unexpected error
January 17, 2014, 06:33 |
Jon Powell
I would get in touch with Ansys Customer Support with the customer portal with this problem, https://support.ansys.com/portal/sit...CustomerPortal
ANSYS Workbench on "Uncertified" Linux Distros | hsr | CFX | 289 | April 20, 2023 09:23 |
Macro command combatibility ANSYS workbench | Tassos | CFX | 6 | January 13, 2014 04:19 |
ICEM CFD in Workbench | marek | CFX | 1 | February 15, 2008 10:35 |
Workbench Transient | Omer | CFX | 0 | January 15, 2007 14:21 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
