October 1, 2009, 13:44 |
Delamination modeling
Hamidreza
Rep Power: 16 |
My thesis is entitled delamination. but I still can't model it by ANSYS.
There are some methods presented in papers but they are not step by step guidlines. I would appreciate if anyone can help me in this regard. Cheers |
November 4, 2009, 02:41 |
Xiaoyan Lu
Rep Power: 16 |
Have you tried using NUMMRG function and gap element(CONTACT element) to simulate that in Ansys?
November 4, 2009, 14:12 |
Hamidreza
Rep Power: 16 |
I have never heard of the first method you mentioned, but the contact element I know that we have to use contact element for delaminated areas, but what should we do for undelaminated area. should they be glued?
I would appreciate if you enlighten it in details. thanks in advance |
November 5, 2009, 10:38 |
Xiaoyan Lu
Rep Power: 16 |
I meant using 'NUMRG' in ansys to merge the keypoints of the undelaminated volume, and leave the delaminated part out. This way, the lines , areas and volumes that contain these keypoints are automatically glued. Check the 'numrg' properties and you can see how. This worked for me. Hope this can help you in your case.
Good Luck! |
November 8, 2009, 13:06 |
Hamidreza
Rep Power: 16 |
Great thanks for your contribution.I managed to use NUMMRG. and I finally modeled the delamination.
but As you mentioned, contact element must be used for delaminated part. which contact elements should be used for a delaminated plate? I create a node component for contact and one component for target area.and then I use contact manager to create contact area. but it is not working. thanks for your time in advance |
November 9, 2009, 00:37 |
Xiaoyan Lu
Rep Power: 16 |
For contact element, I am not very familiar yet. You can try CONTA173 and TARGE170 for 3D modeling. But I haven't tried yet. I did a little research on this before but stopped because other issues. Hope to hear some feedback on that.
May Focus Area: Turbulence Modeling | Jonas Larsson | CFD-Wiki | 0 | May 2, 2006 11:48 |
Modeling Flow/Saturation/Absorption in Fibers | Gene Dougherty | Main CFD Forum | 0 | June 6, 2003 14:49 |
Solid Modeling | Chris | Main CFD Forum | 10 | July 2, 2002 07:12 |
CFD Modeling of Two-phase Flow in Small Dia.Tubes | Eric Poindexter | Main CFD Forum | 2 | September 22, 2000 09:21 |
Extrusion Modeling | Elliot Schwartz | Main CFD Forum | 1 | September 11, 1998 19:08 |
