Ansys 12 Workbench problem when generating volume mesh
Old   September 28, 2009, 09:27
Default Ansys 12 Workbench problem when generating volume mesh
Svein K
Sveink is on a distinguished road
I've just had Ansys 12 installed on my computer, but have encountered a problem.
I start a project, make a geometry, start cfx-mesh and generate a surface mesh without issues. The problem occurs when I try to generate a volume mesh. The bottom left window displaying the progress seems good until it shows "storing volume mesh", and when it gets to "commit mesh" the program freezes and produces this error message: "AnsysWBU.exe has encountered a problem. A diagnostic file has been written: d:\DOCUMENTS AND SET..... .....\Temp\AnsysWBDumpFile.dmp".
Any idea whats wrong would be helpful, thanks in advance.
Sveink is offline   Reply With Quote
Old   November 19, 2009, 13:18
Default similar problem
CFAlex is on a distinguished road
Hey,
I got a similar problem. I can generate the volume mesh but can't commit it to the project. When I try to update the project ANSYS tells me that "The Mesh cell in 'modelname' requires user input before it can be updated.". Anyone got an idea?
CFAlex
CFAlex is offline   Reply With Quote
Old   November 24, 2009, 06:51
Default my solution
Andreas Helbrich
ah_wima is on a distinguished road
Hi there!
Sounds silly, but try updating your video drivers.
That solved the problem for me - the meshing tool kept crashing for no apparent reason during the meshing process with the message described above. Since I updated the driver I haven't had any more problems!
Good luck
Andreas
ah_wima is offline   Reply With Quote
Old   December 21, 2009, 04:07
Default Another problem with design modeler
Praneetha
Praneetha is on a distinguished road
I tried mesh 2-D model. I could finish surface mesh without any problem, but when I tried to import this into fluent and assign boundary conditions I could not assign different boundary conditions to each edge as it is considering all the edges into single surface. How can I solve this problem. Is there any option like split edge?
Praneetha is offline   Reply With Quote
Old   January 5, 2010, 10:13
Default Pay attention to the BC setting
Rikio
rikio is on a distinguished road
Send a message via Skype™ to rikio
Originally Posted by Praneetha View Post
You need to set the boundary conditions within ICEM CFD when do output, if ICEM CFD is used as the meshing tool. And set proper parts for the edges.
rikio is offline   Reply With Quote
Old   January 6, 2010, 03:17
Nguyen Nhat Truong
CCronaldo is on a distinguished road
I think so
quang cao online | quang cao
CCronaldo is offline   Reply With Quote
[ICEM] negative mesh volume problem (icem-cfd/cfx) adam2008 ANSYS Meshing & Geometry 5 April 16, 2010 12:21
Volume mesh problem in STARDESIGN Jaedal Siemens 2 October 17, 2007 09:23
TGRID- Problem in generating Viscous Mesh abhinit FLUENT 3 January 8, 2007 08:48
Help! i need help Mesh volume problem Sergi CFX 1 February 1, 2006 16:29
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
