Importing Temperature Field from CFX to ANSYS |
January 28, 2010, 15:54 |
A.R. Baserinia
Rep Power: 16 |
I am working on a casting problem in which liquid aluminum solidifies in a mold. Since the problem involves both liquid and solid phases, I use CFX to compute the velocity and temperature fields. Therefore, I have the temperature at every single mesh vertex. As the second step, I want to import these vertex temperature values into ANSYS in order to perform a thermal-stress-strain analysis. This step is necessary since the solid metal undergoes elastic-plastic contraction. In ANSYS, I couldn't find out how to import temperature values in the entire volume from the CFX solution. I'd be appreciated is somebody could help me with this. |
February 11, 2010, 13:29 |
Rep Power: 16 |
hallo, i want to do continuous casting simulation for iron. can u help me on that. im very new to this. im using ansys 11. please help me out
Arif |
March 1, 2010, 10:52 |
Hi
ravi kiran
Rep Power: 16 |
Hi baserinia,
Did you find a way out to import from cfx? I am working on a similar problem. Thermal-stress-strain problem of a huge cylinder with inlets and outlets. Working fluid is high temp steam. In CFD-Post try this File>Ansys export/import> Export to ansys load file> pick temperatures. Check this and reply back. If you have already found a solution, please post me. |
ansys, casting, cfx, deformation, thermal analysis |
ANSYS CFX Tutorial | Rashid | CFX | 25 | December 20, 2012 01:22 |
Modifying pressure field in CFX | akultane | CFX | 2 | January 13, 2010 14:42 |
Ansys Workbench (CFX) bucket problem | njsavage | CFX | 1 | April 30, 2009 09:51 |
Importing Ansys .cdb mesh and geometry into CFX 11 | Tom | CFX | 1 | February 18, 2008 11:08 |
I cannot open Ansys CFX in Workbench | Pham Son Minh | CFX | 2 | January 13, 2008 03:33 |
