Home > Forums > Software User Forums > ANSYS
Problems with generated results of 3D wing analysis
Old   March 12, 2010, 10:37
Default Problems with generated results of 3D wing analysis
Chong Shao ming
Shaoming is on a distinguished road
I am using Fluent to analyse a typical 3D wing problem under low Re. However, the CL which was obtained is way too high in region of 3.7 for AoA of 4!
(selected results from force report)
Force vector: (0.06976 0.997564 0)
pressure total pressure total
force force coefficient coefficient
n n
2.2806709 2.2830547 3.7235443 3.7274363
Could anyone help verify if the parameters used are suitable and correct?
Fluent
(grid checks and scaling have been carried out correctly)
Solver: Pressure-based
Materials: constant density and viscosity
Viscous Model: Spalart-Allmaras (at default values)
Operating Conditions: Op pressure = 101325 Pa
Boundary Conditions: (kindly refer to attached file)
Inlet-velocity inlet
Outlet-pressure outlet
Kindly point out any possible loopholes which i might have in the meshing as well. (FYI airfoil used is GEMINI, c=0.171m, b=1.2)
Thanks in advance!
Shaoming is offline   Reply With Quote
Old   April 11, 2019, 00:56
veerappan
veera is on a distinguished road
that first force vector is x component ?
x=sin alpha?
veera is offline   Reply With Quote
Old   April 11, 2019, 01:20
Default 3d wing
veerappan
dear seniors
actually i am simulating naca4412 3d airfoil wing for downloaded conference paper , in that paper i got results , but my solution is very low in the two order deviated from his values
for example . paper result is at 0 AOA , cl=0.0018, cd =-0.05
but my result is cl=0.0016, cd =0.00016
similarly at 5 AOA , PAPER RESULT IS CL=0.2 , CD = 0.1
but my result again cl= 0.0023 , cd = 0.0003
what any thing wrong in inlet parameters what i gave , or in scaling factor , waiting for your response
3D Wing Analysis Ed FLUENT 5 April 13, 2019 13:07
multi wing element - negative coefficient of drag? Zweeper FLUENT 10 March 11, 2010 12:20
Problems with repeating results Lee Siemens 4 May 26, 2006 03:39
problems viewing results with VNC Ralf Schmidt FLUENT 3 February 1, 2006 01:40
Boundary layer on a wing Mark FLUENT 0 August 18, 2004 20:24
