April 6, 2010, 17:09 |
How to simulate a gripper
Max
Rep Power: 16 |
I am trying to simulate in ANSYS Workbench 12 a gripper made in only one piece. It is designed to be in plastic. I succeed to simulate it alone, but I don't when I try to simulate the gripper grasping something (here a cylinder). The gripper pass through the cylinder, whereas it should adapt itself around it. The gripper is a part imported from Catia, and the cylinder is just an extrusion in ANSYS. I set a fixed support in both screw holes of the gripper, and on the lower face of the cylinder. I also impose a displacement at the bottom of the gripper. Here are 2 screenshots: The first represents the Displacement and fixed supports The second represents the problem that I have after deformation I really don't know why it doesn't work. If you could help me I would be grateful! Thx! Max |
April 7, 2010, 03:53 |
Michiel
Rep Power: 16 |
Well, this is no CFD but structural finite element analyzing.
Looking at the tree outline of your project I see you don't have any contacts defined. And that is your problem. If you want the model the interaction between parts you must define contact pairs. To ad the contact: right click on the 'connections' object and insert a 'manual contact region'. Define contact and target areas, one should be the cylinderical surface, and the other should be the face on the gripper which will be in contact with the cylinder. You will need two of these contacts, one for each gripper arm. For contact type select frictionless or frictional. For other settings i recommend you read the help files on this subject. |
April 7, 2010, 11:47 |
Max
Rep Power: 16 |
Hi Michiel,
Thanks for helping me. I tried what you said, but it didn't work. I add 2 Solid to Solid contacts between the cylinder and both arms of the gripper. I tried every type of contact (frictional, frictionless, rough ...), but it didn't change anything I now have these error messages: - "Warning: One or more bodies may be underconstrained and experiencing rigid body motion. Weak springs have been added to attain a solution. Refer to Troubleshooting in the Help System for more details. Project>Model>Static Structural>Solution" - "Warning: Contact status has experienced an abrupt change. Check results carefully for possible contact separation. Project>Model>Static Structural>Solution" - "Warning: One or more contact regions may not be in initial contact. Check results carefully. Refer to Troubleshooting in the Help System for more details. Project>Model>Static Structural>Solution" So I tried to add 2 frictionless supports at the bottom of both cylinder and gripper to constrain them more, but it didn't change anything either. Thx! Max |
April 9, 2010, 13:37 |
Max
Rep Power: 16 |
up plz!
Car fire in an underground park - Simulate a temperature sensor | psc3 | Fluent UDF and Scheme Programming | 9 | June 9, 2014 06:16 |
can STAR-CD simulate a solid transfering heat ? | lenson | Siemens | 6 | December 30, 2005 03:13 |
Please help me to simulate a river using CFD-ACE+ | Sas | Main CFD Forum | 0 | August 27, 2002 20:51 |
How to simulate.. | Sharad Dugad | FLUENT | 0 | March 12, 2002 15:27 |
What is best way to simulate big particle | yueroo | FLUENT | 2 | April 13, 2001 21:28 |
