Trouble with ansys workbench !!!
Old   April 13, 2010, 15:58
Question Trouble with ansys workbench !!!
adminCAE
mechanicaldesign is on a distinguished road
Hi all,
When I want to launch ANSYS Workbench 11 in linux CentOS 5.4 64 biti I encoutered the next message:
>su
>password
>./runwb
>./runwb: line 24: 5827 Segmentation fault $DS_INSTALL_DIR/workbench -StartPage $*
What means this error ? How I can fixed? You have any ideea ?
I waiting much early is possible your suggestion, referring to my problem.
Thank you very much for support and understanding.
Best regards.
Mess with the best die like the rest ... ANSYS is the best !!!
mechanicaldesign is offline   Reply With Quote
Old   April 14, 2010, 08:55
Default TechSupp?
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Hmm, I can’t tell from here, but I would suggest sending this into to Tech Support… I am not sure what phone number you would use in Romania, but you could try the customer portal… https://www1.ansys.com/customer/
Since you have all the specifics, they are probably your best bet for getting this answered quickly.
PSYMN is offline   Reply With Quote
Old   April 14, 2010, 09:05
Default Workbench 11.0 not available for Linux...
PSYMN's Avatar
Simon Pereira
Oops, on my first quick read, I didn’t connect the dots between Workbench 11.0 and Linux… I don’t think Workbench supported Linux at WB 11.0. I am not sure how you even got that far...
You would need Workbench 12.1.1 to be properly supported on Linux (available from the customer portal https://www1.ansys.com/customer/ ). You would also want to check the documentation to make sure it is certified on your particular Linux OS…
Old   April 14, 2010, 10:15
Default Confirmed...
PSYMN's Avatar
Simon Pereira
I just confirmed that Workbench 11.0 is NOT supported on that operating system...Actually nothing was supported on that Operating system at 11.0.
http://www.ansys.com/services/ss-110...rm-support.pdf
workbench 11 on linux
ANSYS Workbench on "Uncertified" Linux Distros hsr CFX 289 April 20, 2023 09:23
[ICEM] what does the different ANSYS ICEM and ANSYS Workbench? agungwp ANSYS Meshing & Geometry 8 April 12, 2016 04:51
Macro command combatibility ANSYS workbench Tassos CFX 6 January 13, 2014 04:19
Ansys workbench problem Jonny6001 ANSYS 2 September 30, 2010 12:59
Export Heat Flux CFX -> ANSYS Workbench Freeman CFX 2 April 11, 2010 08:24
