-   ANSYS (http://www.cfd-online.com/Forums/ansys/)
-   -   Increase chart points (http://www.cfd-online.com/Forums/ansys/75564-increase-chart-points.html)
Felipe Matos April 28, 2010 20:15
Hi
I'm trying to increase the number of data points in my chart. How can I do it? Can I use use some kind of "concentration" distibution like increase the number of points in some areas and decrease in others?
Thanks
Josh April 29, 2010 16:58
If you're setting a location (e.g. a polyline that wraps around an airfoil) that you're extracting the data from, then in Post, open up that (polyline) and increase the amount of points.
Felipe Matos May 8, 2010 16:37
Yes you can.
You need to go to the locantion options (line, for example). In the general tab, there is the kind o samples you want to get:
- cut: get samples at the same rate as your mesh
- samples: define the number of equaly spaced samples
Thanks
