April 28, 2010, 20:15 |
Increase chart points
FM
Rep Power: 16 |
Hi
I'm trying to increase the number of data points in my chart. How can I do it? Can I use use some kind of "concentration" distibution like increase the number of points in some areas and decrease in others? Thanks |
April 29, 2010, 16:58 |
Joshua Counsil
Rep Power: 17 |
If you're setting a location (e.g. a polyline that wraps around an airfoil) that you're extracting the data from, then in Post, open up that (polyline) and increase the amount of points.
May 8, 2010, 16:37 |
FM
Rep Power: 16 |
Yes you can.
You need to go to the locantion options (line, for example). In the general tab, there is the kind o samples you want to get: - cut: get samples at the same rate as your mesh - samples: define the number of equaly spaced samples Thanks |
Sliding Interface issues | philippose | OpenFOAM Running, Solving & CFD | 7 | May 5, 2014 03:13 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
Problem in CFX5POST Chart function. | windhair | CFX | 2 | September 20, 2004 07:49 |
extreme points problem | Lipo Wang | Main CFD Forum | 2 | August 18, 2004 03:15 |
