June 6, 2010, 16:48 |
File import from Solidworks to ICEM
Hi Folks,
i need to mesh some turbine rotor geometry. Due to that, I have constructed the geometry in Solidworks and now want to mesh it using ICEM. Normally, I did this in the following way: 1.) exporting the geometry from solidworks as an .igs-file 2.) deleting all the available curves and points 3.) building a new topology to create new curves using a model topo tolerance of about 0.00001 (my geometry is about 70mm long) This time, I experienced the problem that the build topology function produces all bended curves in yellow colour (which would mean they are not connected to all attached surfaces. Does anyone have a hint how to solve this problem and to get to a good geometry? Thanks a lot, Dreamdancer |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
