incorrect grid motion
Old   June 7, 2010, 07:43
Default incorrect grid motion
Ambareesh Rishi
ambareesh13 is on a distinguished road
I am modelling flow around a vibrating cylinder.i have successfully compiled and hooked this UDF but i am continuously getting this error.
Warning: incorrect grid motion UDF valve::libudf on zone 6 (assuming no motion).
is something wrong with my UDF or compiler
This is my UDF
#include<udf.h>
#include<math.h>
#define A4 1.25
#define F4 0.255
DEFINE_CG_MOTION(vibration, dt, cg_vel, cg_omega, time, dtime)
real st;
real va;
va = A4*2*M_PI*F4;
cg_vel[0] = 0.0;
cg_vel[1] = va*cos(2*M_PI*F4*time);
cg_vel[2] = 0.0;
NV_S(cg_omega, =, 0.0);
ambareesh13 is offline   Reply With Quote
Old   July 14, 2010, 04:51
Herman
enry is on a distinguished road
Hi ambareesh13,
I have the same problem, compiling a UDF written for fluent 6.3.26... I wrote an UDF that work well in fluent 6.3.26, but it doesn't work when I compile the same UDF in fluent 12. I tried also to compile an other udf finding on cfd on line, that was written for fluent 12, but the same problem appears on the screen.
Have you solved your problem? Could be a library problem?
Thanks in advance.
enry is offline   Reply With Quote
UDF problem: incorrect grid motion Fil FLUENT 5 December 19, 2020 09:16
Grid motion with UDF fivos Fluent UDF and Scheme Programming 5 June 30, 2018 08:50
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
MapFields to New Grid For Extreme Grid Deformations due to Body Motion albcem OpenFOAM 0 May 5, 2009 14:17
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
