Pitch and frame change
Hi all,
Just a quick question. I'm simulating a rotor and the CFX literature often refers to pitch change and frame change at the interface between rotor and stator. I roughly undestand the principle but I don't really see a difference in the two. Could someone explain them for me as I can't find a definition anywhere? Many thanks, Andy |
Also you have made this post nearly one month ago I will give you an answer:
A Frame Change occurs when you change the speed of rotation (for example from 310 rad/s to 0 rad/s -> Rotor - Stator). A change of speed from 310 to 155 rad/s is another example. In CFX you can do such a frame change with a Stage or with a Frozen Rotor Interface. Pitch change is necessary if the number of blade is different. Example: 4 blades in rotor, 5 blades in diffusor. The pitch change describes the ratio between those different numbers (in this example 0.8). |
Thanks for that. That makes much more sense now..
Just to clarify, is Frame Change for the two domains at a point in time (ie stator is stationary @ 0rad/s while the rotor is rotating at 310rad/s) or for when the relative rotational speed changes in time (ie, relative rotation between rotor and stator is 310rad/s and then changes to 0rad/s)? I think its the first option but I just want to be clear. |
Frame Change is for one point in time. Your first assumption is correct.
Your second example (reduction of rotational speed from 310 rad/s to 0 rad/s) requires a transient simulation. Therefore you can nevertheless use a frozen rotor interface (as far as i know). In this way both of your assumptions should be correct (the first one is to 100% correct, for the second assumption I'm not 100% sure). |
Great, thanks..
