Home > Forums > ANSYS
Mesh Check Failed, Please Help!
Old   August 20, 2010, 23:07
Default Mesh Check Failed, Please Help!
fyp
FYP
fyp is on a distinguished road
When using FLUENT to check mech, there is an error message saying that "Warning: mech check failed". But it had passed the mesh check by using ICEM. Please advice. Thanks.
fyp is offline   Reply With Quote
Old   August 26, 2010, 00:05
Arash
arash_7444 is on a distinguished road
probably, skewness of your mesh is high
is that right?
arash_7444 is offline   Reply With Quote
Old   August 27, 2010, 06:41
fyp
FYP
yes, you are right.
thanks
Old   August 28, 2010, 18:09
Rupak
rupakbanerjee is on a distinguished road
same problem.
do i use a smaller mesh spacing?
rupakbanerjee is offline   Reply With Quote
Old   August 29, 2010, 05:41
Ben Jimenez
descendents1 is on a distinguished road
If you are certain skewness is your problem, locate where your problem cells are located. Then you'll want to refine your mesh in those regions (as it is likely there is a cluster of highly skewed cells). Don't refine your entire mesh only to fix one small problem area as it will cut into computation time.
descendents1 is offline   Reply With Quote
mesh check failed
Thread Tools
Trackbacks are On
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 40 January 20, 2016 01:08
Transient boundary conditions Jarrod Sinclair (Sinclair) OpenFOAM Running, Solving & CFD 133 May 6, 2015 06:21
mesh check failed / degenerated contact points shohin FLUENT 16 April 11, 2014 22:32
Check the skewnesses of your face meshes and make sure the face mesh sizes are not to sophie-l ANSYS Meshing & Geometry 0 April 13, 2009 17:27
user defined function cfduser CFX 0 April 29, 2006 10:58
