How to measure total Heat Power
1 Attachment(s)
Hi every body .
I'm learning to use Ansys ICepak to solve Heat problem . How ever I don't know to measure or get information about the most important thing in Ansys Icepak_ Heat power. I'm searching some datasheets about : transistor, capacity and fan. However i don't know how to see the heat power because i'm ameatur . CAn you help me? Thanks you very much. Here is an example of a transistor's datasheet that i attached. |
Can anyone help me please?
Usually, objects such as transistors are not modeled in ICEPAK. What you could do is to either modeled it as a planar (2d) or volumetric (3d) heat source. For most packages, such as BGA where the heating is usually a very thin layer, a 2D source is a gd simplification. For others where the temperature gradient in the block is important, den assigning a power to a block with thermal conductivity is good enough. However, if that is not important but you wanna retain the geometric characteristics of the block (for flow analysis), then you can use a 3D source.
After solving, you may wanna check how much of the heat flow goes to each of the 6 sides. So you can go to report summary and choose the object and indicate its high/low side. If all 6 sides are needed, than you can unchecked the combined values. For fans/opening, you can do the same as well. maybe you can describe in more details what you wanna model, and I can help you further. |
Hi Bighead. I appriciate that you answer my question. However I think you maybe misunderstand. I already know how to model an Ansys Model but my question is "how to get information about the heat source?" . How to measure total heat power of an object by someway such as datasheets.. to fill information in Ansys model. Can you help me please? If you don't mind we can contact by email. Myemail is "clbhtsvnguyenmanhcuong@gmail.com". Thank you very much. Have a nice day. |
OK. thank for your help. I think i must ask my tutor. ^^
Sorry for my misunderstanding.
For most packages, there is usually a thermal design power (TDP) for steady state calculation. For transistors, its usually related to the current at the gates (Joule heating). These can be used as a starting point till you get more info from measurements. There are plenty of work done at the device level in thermal modeling. I think your answer can be found in the publications there. |
