Suggestions for simplyfying propeller geometry?
Old   May 9, 2011, 14:44
Default Suggestions for simplyfying propeller geometry?
Mike
mmn1239 is on a distinguished road
I am trying to create a volume mesh for a propeller and plane body, but I am having great issues using clean up tools etc. It is imported as a parasolid body from solidworks ( originally from http://grabcad.com/library/xoar-21x8-propeller), and in solidworks I have tried numerous techniques trying to create a one solid surface/volume from the faces - but to no avail.
Once imported into gambit I am running clean-up diagnosis for sharp angles, and employing the chop feature to clean these up. Then I am trying to convert these virtual faces that this feature creates into real faces, and some of these will not convert. I have also tried to merge faces, and then convert the resulting virtual volume into a real volume and this crashes gambit. I will attach the gambit files - let me know if anyone has any suggestions for simplifying/cleaning up the propeller geometry.
Thanks!
mmn1239 is offline   Reply With Quote
Modelling a propeller tomg STAR-CCM+ 4 April 28, 2011 17:22
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
Propeller or fan geometry Roger FLUENT 0 May 7, 2007 06:32
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
propeller geometry Tomas Andersson FLUENT 0 February 27, 2001 09:01
