Home > Forums > Software User Forums > ANSYS
Exporting fluent melting/solidification model results to ansys mechanical apdl
Old   October 16, 2010, 10:36
Default Exporting fluent melting/solidification model results to ansys mechanical apdl
omair
omair11 is on a distinguished road
Hello everyone
I am new to ansys so please forgive me if this sounds like a stupid question.
I am solving a continous casting type problem in fluent. In fluent i can allow the material to "flow" through the stationary grid because of the nature of the transport equations.
Now i want to do stress analysis in ansys mechanical apdl. however, i dont know if the stress equations can accomodate a material that is moving through the stationary mesh.
Can anyone please tell me what is the best way to do this?
omair11 is offline   Reply With Quote
Old   March 19, 2011, 08:46
Default hi
ramkrishna
rakhirama is on a distinguished road
iam working on solidification/melting problem using fluent software.the problem is basically tube and tube heat exchanger problem.inside tube water is entering with velocity 0.25 m/sec& 37.7 degree C ,and leaves the pipe with pressure outlet.and phase change material(pcm) is filled in the gap between inner and outer cylinder.the phase change material is stationary outer suraface of the cylinder is completly insulated. and lateral surfaces of the cavity space is also insulated.only water is entering at left face of the inner tube and leaves at right face.
melting?solidification temp is 27.7 degree centigrade.intially both water and pcm are at 26 degree centigrade.
boundary conditions
1)water
1) velocity inlet 0.25m/sec and 37.7 degree centigrade
2)for outlet is i took pressure outlet with 0 gauge pressure.
phase change material no boundary conditions
for phase change material the heat is transfered in the natural convection way
so i used boussing equation used in density variation.
mesh check is done correctly
but
when problem is iteration the residuals are up to some point decreasing and then maintaining constant. i tried changing the under relaxation parameters but till my problem is not converging.
plz help me i strucked. my emial id is nrk.gec@gmail.com
thank u
rakhirama is offline   Reply With Quote
Old   March 19, 2011, 08:47
ramkrishna
[QUOTE=rakhirama;300165]iam working on solidification/melting problem using fluent software.the problem is basically tube and tube heat exchanger problem.inside tube water is entering with velocity 0.25 m/sec& 37.7 degree C ,and leaves the pipe with pressure outlet.and phase change material(pcm) is filled in the gap between inner and outer cylinder.the phase change material is stationary outer suraface of the cylinder is completly insulated. and lateral surfaces of the cavity space is also insulated.only water is entering at left face of the inner tube and leaves at right face.
boundary conditions
1)water
but
thank u
Old   August 28, 2013, 06:22
rocky
ambrish4u is on a distinguished road
Originally Posted by omair11 View Post
Hello everyone
@omair11
i am also working on stress analysis as you in continuous casting. i am not able to export data from fluent to ansys. does i have to make new fea file (new geometry and meshing) for input fea file. will you please help me out if you have got the solution.
thanks in advance...
ambrish4u is offline   Reply With Quote
ansys fluent, ansys mechanical apdl, fsi
Exporting Pressure data from FLUENT to ANSYS Whats_in_a_name FLUENT 7 September 3, 2017 03:09
[GAMBIT] 3.5 years overtake by Ansys: Where are the enhancements in grid generation Volker P. ANSYS Meshing & Geometry 22 January 17, 2012 17:27
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 01:10
simulation results for k-w model and SST model Li CFX 7 June 29, 2007 04:19
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
