November 24, 2010, 22:11 |
Meshing problem
Derwin Parkin
http://www.flickr.com/photos/derz/5205319511/
See this picture? Notice in the middle of these regions, the mesh is coarser in the middle. How can I eliminate this? I would like the mesh to be as fine as it is at the region-boundaries, all the way through the region... Any thoughts? I've tried playing around with many options but can't seem to eliminate it with automatic/tets meshing... |
November 25, 2010, 05:51 |
On the left side in the settings look at sizing: When you decrease the Max Tet Size you force Meshing to use smaller (and more) elements to mesh your geometry.
Also try changing the growth rate. To achieve a slower growth in element size choose values close to 1 (e.g. 1.05). |
November 25, 2010, 08:47 |
#3 | |
Amir Khodabandeh
I also think u set growing rate wrong. u should inverse it or if boundaries are important use double method(it got different names, iirc in gambit it is bell method!) which get 2 values for each end! |
November 30, 2010, 13:20 |
its a sizing ans infilation problem
December 2, 2010, 21:50 |
Darren Leong
Hi Derz,
1. You'll have more control by editing through CFX-mesh. Reduce the body spacing from there when meshing. There doesn't seem to be an inflation layer around your model, may have problem with the turbulence models later on. 2. You can extend the inner domain to capture the wake area and have the coarser mesh as your outer domain. This eliminates errors at the domain interfaces (lost of flow information). The outer domain should be bigger to reduce the chance of blockage effect. |
[Other] Hex meshing problem DM12 | patrick | ANSYS Meshing & Geometry | 7 | January 9, 2015 07:21 |
Gambit meshing problem | nana | ANSYS Meshing & Geometry | 5 | August 31, 2009 05:58 |
Meshing problem in GAMBIT | Vidya Raja | FLUENT | 0 | May 20, 2006 23:31 |
Problem meshing very thin pipe | B. Hemmen | FLUENT | 2 | May 16, 2006 08:29 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 09:22 |
