Link or Extension to CFX/Fluent
Old   November 30, 2010, 18:57
Question Link or Extension to CFX/Fluent
Ghasem Bashiri
Ghasem is on a distinguished road
Dear All
We know most software with their Gherapical User Interface. But Advanced Software can let users to write some codes as extension to increase software flexibility. Sometimes software let us to use some external link to other softwares. For example with link to Visual Basic or Excel it is possible to perform some programming.
I checked interface of Fluent generally for porous media. But it is far from porous media concept in oil and gas reservoir simulation. Therefore I assume it may be possible to wirte some coding to Fluent (and CFX) and then ask from them to run it. Within such coding we should can define our system equation with required input data.
As an example within MATLAB there is such option. Matllab has user interface for PDE. But at same time it is possible to write some codes (with predefined instruction) and then ask from MATLAB to run it.
Is there any similar facility within Fluent/CFX or other CFD Codes?
Ghasem Bashiri
Ghasem is offline   Reply With Quote
Old   December 9, 2010, 20:46
los
Tiago Macarios
los is on a distinguished road
CFX has a FORTRAN interface, I have never used it but I heard it is really complicated and bad documented.
FLUENT has UDF (User Defined Functions) which is also a interface for C, C++ and FORTRAN.
FORTRAN example: http://my.fit.edu/itresources/manual...df/node130.htm
C example: http://my.fit.edu/itresources/manual...df/node231.htm
C++ examples can be found at the ANSYS customer portal
Anyway, if you are just starting and want to do things right, why dont you use openFOAM?
los is offline   Reply With Quote
Problem with paraFoam ata OpenFOAM 14 November 30, 2009 04:23
[OpenFOAM] Xwindows crash with paraview save srinath ParaView 1 October 15, 2008 09:37
CAPTCHA extension activated Jonas Larsson CFD-Wiki 0 June 15, 2007 18:20
ReleaseNotes13 website link problem maka OpenFOAM 2 November 22, 2006 04:32
Extension of interpolation files Ale FLUENT 0 October 15, 2003 09:07
