ANSYS/CFX, MFX procedure problem
Dear all:
I have a procedure question about MFX with ANSYS/CFX. After you created your *.cbd files for both mechanical and fluid problems, and the *.def file for fluid definition, is there a good way to run batch mode to get your simulation results? If so, would you be so kind to share your batch code? Thank you so much for your help! Best regards, Ryan |
