-   ANSYS (http://www.cfd-online.com/Forums/ansys/)
-   -   Read Result Files or User Defined Result (http://www.cfd-online.com/Forums/ansys/84807-read-result-files-user-defined-result.html)
Aquilaris February 9, 2011 05:25
Hi, what I want to do is to create a colored geometry of a result file that I have modified. I guess it has to be done with the "Read Result Files" in the Mechanical Workbench but the button is grey and so unavailable.
I have other option which is to make an User Defined Result and write an expression there with the equation that I used to generate the results. But since that equation depends on the position of the nodes, and there are no User Defined Results Expressions relating to node position, I'm stuck here as well.
Thanks in advance, hope you can help me.
