Krischan |
February 16, 2011 08:11 |
Ansys 12.0 on Ubuntu 10.10 64bit
I'm trying to set up Ansys 12.0 on a computer with Ubuntu 10.10 64bit and running into some problems.
The INSTALL script worked without any errors, however then programs won't.
What's working:
CFD Post
CFD Solver Manager
The connection to our license server is also fine
What's not working:
CFD Pre (just hangs when I try to start it, so no window appears etc)
ICEM
ICEM especially throws some errors when I try to run it, but that isn't very helpful to me:
syntax error in expression "$tcl_version < 8.0": extra tokens at end of expression
("if" test expression)
while compiling
"if {$tcl_version < 8.0} {
proc blt_table_column {w args} {
eval blt_table column $w $args
proc blt_table_row {w args} {
eval blt_tabl..."
invoked from within
"if $has_blt {
(file "/ansys_inc/v120/icemcfd/linux64_amd/lib/guibase/forms.tcl" line 3505)
invoked from within
"source /ansys_inc/v120/icemcfd/linux64_amd/lib/guibase/forms.tcl"
invoked from within
"script_interp eval [list source $guibase_dir/$f.tcl]"
(procedure "setup_batch_interp" line 184)
invoked from within
(procedure "SetupMedBatchInterp" line 32)
invoked from within
"SetupMedBatchInterp "
(procedure "InitializeMed" line 4)
invoked from within
"InitializeMed"
(procedure "AIEnvMain" line 190)
invoked from within
"AIEnvMain"
(file "/ansys_inc/v120/icemcfd/linux64_amd/lib/ai_env/init.tcl" line 1719)
invoked from within
"source [file join $env(ICEM_ACN) lib ai_env init.tcl]"
invoked from within
"if {[info exists env(ICEM_AI_ENVIRONMENT)] == 1} {
if { $env(ICEM_AI_ENVIRONMENT) == 1 } {
if {[info exists env(MED_ROOT)] &&
(file "/ansys_inc/v120/icemcfd/linux64_amd/lib/med/med_start.tcl" line 27)
invoked from within
"source $med_root/lib/med/med_start.tcl"
invoked from within
"if [file exists $med_root/lib/med/med_start.tcl] {
} elseif [file exists $med_root/../med/lib/med/med_start..."
Any help getting this to work is appreciated.
Thank you
Christian
