February 24, 2011, 07:48 |
problem in the CFX12.1 parallel computation
Rep Power: 15 |
I am using the LINUX CFX12.1 parallel computation to modeling an axial compressor flow. The total grid elements is about nine million. Eight computers were used with a HP MPI distributed parallel.
The problem is that the computation stopped at about 40th step, with no error pop out. I am sure the CPU and memory is sufficient for the computation, but why i got the interruption? Another problem is that should I do anything when I manually stopped a MPI parallel computation. I find that, the computation become slow when it is started after a parallel computation stopped. Thanks firstly, BalanceChen |
March 1, 2011, 07:20 |
Problem has been figured out in the CFX12.1 parallel computation, Thank you~
Rep Power: 15 |
I choose the partition type to "uniform" and then the problem dissappears~
July 7, 2011, 10:26 |
#3 | |
mohammad
Rep Power: 16 |
I have a question to ask. I'm using the same CFX and I want to use a supercomputer with 4nodes*4 ppn= 16 my problem is that when I use serial it solve about 12 iterations per hour. when I use any parallel or Distributed parallel the speed is slowerrrr.. 2 iterations per hour. do you know why? regards. |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
Parallel communication problem, port 8676 | jreig | FLUENT | 3 | May 28, 2010 02:24 |
problem using property udfs in parallel mode | EllenW | Fluent UDF and Scheme Programming | 5 | July 10, 2009 04:31 |
Fluent parallel license problem | brothershuai | Main CFD Forum | 0 | July 1, 2009 15:41 |
how to parallel computation | Jane | Siemens | 2 | April 28, 2004 06:11 |
