heat transfer using ansys
Old   August 24, 2011, 02:15
Default heat transfer using ansys
Aly
Aly
Aly is on a distinguished road
Hi ,
I spent much time trying to figure out how to make the heat transfer analysis for moving fluid inside pipe
all I want to do is to pass a flow of air into a pipe , have a cooler half way ,
and come out with the results (pressure , density , mass flow rate , temperature) at the end of the pipe
I'm trying with cfx now
please help
Aly is offline   Reply With Quote
Old   September 7, 2011, 08:05
Graham81 is on a distinguished road
Aly,
Using CFX, you can define two domains (just the pipe and the fluid) and connect them through a thermal interface. You can impose a flux at the point the cooler would be and track the fluid, just set up the geometry in DM ("pipe in pipe").
Best regards,
Graham
Graham81 is offline   Reply With Quote
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 15:35
Help with mass transfer in heat and water vapor exchanger mullenc525 CFX 7 January 25, 2011 23:26
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
exporting heat transfer coeff. to ANSYS H.K.MANAT FLUENT 0 November 30, 2001 06:46
