Problem with Volumes Gambit
Like Tree1Likes
  • 1 Post By -mAx-
Old   October 19, 2011, 07:58
Default Problem with Volumes Gambit
Evangelos
Danath is on a distinguished road
Hello !
i have creates two volumes(create real brick).These volumes are side by side (the side of a volume is glued to the side of the other volume)
when i try to merge the volumes i see a message that says that "Error: Volume volume.X can not be merged with other volume(s) (it is disconnected)"
When i try to create the volumes with edges everything is ok!(because i take the face of the first volume as the face of the other)
can i connect the volumes without change the drawing ?
Danath is offline   Reply With Quote
Old   October 19, 2011, 08:20
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you have 2 common faces superposed.
Then connect the 2 surfaces, it won't merge your 2 volumes.
But after connecting you will be able to merge the volumes.
PS: There is a subforum dedicated to Ansys Mesh:
http://www.cfd-online.com/Forums/ansys-meshing/
You will have more chance to get a quick reply
Mar777 likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
problem importing mesh into gambit tsm554 FLUENT 7 December 3, 2010 22:15
Problem importing solidworks to gambit holyo ANSYS Meshing & Geometry 3 April 16, 2010 05:16
Problem with Gambit Diego FLUENT 0 July 5, 2007 03:30
Startup Problem in Gambit 2.2 with WindowXP Win Win Maw FLUENT 3 January 25, 2006 11:09
problem in CFX solver about isolated volumes Yuan CFX 2 August 16, 2004 22:54
