Swirl fraction or swirl degree, please help me |
April 19, 2017, 04:03 |
Emily
Rep Power: 9 |
Dear all,
I am trying to follow a paper about spray drying and air flow simulation then I am trying to get a same result with the paper. The flow of in a spray dryer is turbulent and two-phase (air and droplet). K-e(realizable and standard wall function) model have been using for turbulence. In the discrete phase model DPM, injection type is a cone, then I defined cone injection with Rosin Rammler distribution method. There is a parameter which is swirl fraction. Do I have to define this? Paper given me swirl degree is 5 degree and water velocity is 49m/s. I little confused with this two parameters. Should i find it? Where i could define swirl degree, what is swirl degree. Is it important? Thank you so much, |
April 19, 2017, 04:08 |
Paper survey
Emily
Rep Power: 9 |
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel | Mehrez | OpenFOAM Running, Solving & CFD | 10 | May 18, 2016 11:44 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
