October 6, 2011, 03:33 |
ansys workbench meshing ====help
suzhuming
question1: what does connection meanning
question2: how to improve the quelity of meshing |
December 15, 2011, 05:06 |
connection
In ansys connection is used for establish connection between parts in assembly.u can also used for contact analysis or specifying spring connection
December 16, 2011, 10:35 |
Rep Power: 14 |
Question 2:
Meshing is a multiphysics soft but it works almost in the same way to mesh. For CFD, don't forget to use Physics: CFD. You can improve your mesh by controlling global parameters (Click on Mesh/Details appearing at the bottom of the window) and by having mesh method or local control (Right Click on Mesh: Method for mesh method (tetra hexa) or others features for local control (inflation/sizing...) You can check the mesh quality by using "statistics" (last global feature) and choosing the criteria associated: skewness or Orthogonal quality now |
December 17, 2011, 16:20 |
Antonio Alvarez
Hello
is any tutorial about how to use the CFD on the net I will apreciate http://www.plantillaexcel.com |
ANSYS Workbench on "Uncertified" Linux Distros | hsr | CFX | 289 | April 20, 2023 09:23 |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 05:22 |
[ANSYS Meshing] Ansys meshing with extended meshing | jsm | ANSYS Meshing & Geometry | 6 | January 10, 2011 12:09 |
Ansys workbench problem | Jonny6001 | ANSYS | 2 | September 30, 2010 12:59 |
Meshing In Ansys Workbench For Fluent (Refinement) | FAU_OceanEng | FLUENT | 0 | May 31, 2010 17:12 |
