-   ANSYS (http://www.cfd-online.com/Forums/ansys/)
-   -   help need for my project: design n simulation of ic engine (http://www.cfd-online.com/Forums/ansys/97153-help-need-my-project-design-n-simulation-ic-engine.html)
sid87 February 9, 2012 21:05
hi all,
i m student of BE mech. engg. i m working on project of design n simulation of ic engine. can any 1 recommend me which s/w will be best to work on????
i would be thankful if any can briefly help me in approaching this project...
thank you
with regards
sid
tsram90 February 10, 2012 10:01
One of the most simple and most used ones is Fluent and Gambit or the latest version called Ansys workbench.
make sure what you are analyzing.. Like combustion pattern, Formation of soot/Nox, Effect of different fuels, effect of diff injection/spark timings etc.
sid87 February 10, 2012 12:49
thank you very much for the info... is it possible to work only on ANSYS 13???
tsram90 February 10, 2012 13:01
in my personal experience I had trouble running Ansys 13.. And Ansys 13 miss Gambit. If you are starting fresh it might not be a problem
sid87 February 27, 2012 09:21
if i m using ansys 14 how do i start ????
sheth February 27, 2012 23:03
As you said you're working on BE project, I assume that you have very limited time to complete.
IC engine simulation is not just one small things actually many small analysis are involved, and learning each of them in short time might be difficult.
It can mainly be classified in structural and fluid analysis, and there is FSI (fluid structure interaction), in FSI you study effect of fluid on structure or vice-versa.
If you're from mechanical stream you should opt some structural analysis and if you would like to do fluid analysis (using CFD), learn from some research papers/project first and then use CFX or Fluent tutorials. Although cfx doesn't have particular ic engine tutorial, it has some other relevant tutorials.
