FSI Question
Old   February 24, 2012, 11:11
Default FSI Question
sheth roh
sheth is on a distinguished road
IS FSI possible with multibody having some relative motion in ANSYS.
In my analysis, I started ANSYS Transient Module. The analysis I am doing consist some relative motion between two body, one is fixed and one has revolute joint. I am analysing how this relative motion will affect the flow around it.
The ANSYS solver is run first and then CFX. When I setup everything and run the ANSYS solver gives this error:
*** WARNING *** CP = 0.594 TIME= 21:41:04
ANSYS results must be written into the database for Multifield
analysis. The /CONFIG,NOELDB,1 command is ignored.
SERVE GLOBAL COUPLING INFORMATION
ADDITIONAL SYNCHRONIZATION FOR CFX:
SECOND SYNCHRONIZATION POINT OF MASTER CODE:
GET INTERFACE MESHES, INITAIL VALUES, and RESTART LOADS
*** ERROR *** CP = 0.641 TIME= 21:41:05
CONTAC171 through CONTAC177 elements with KEYOP(2)=2 are invalid
elements for the Multifield Solver.
2nd sync. point: Get interface mesh
*** ERROR *** CP = 0.703 TIME= 21:41:05
Error during setup - Skipping the remaining MultiField analysis.
sheth is offline   Reply With Quote
Fluid-Structure Interaction (FSI) with OpenFOAM rlc138 OpenFOAM Running, Solving & CFD 27 February 9, 2018 19:51
[Other] Remeshing fails in FSI pramo4d ANSYS Meshing & Geometry 0 February 17, 2011 05:14
User-defined force transfer across FSI interface vivekcfd CFX 7 March 10, 2010 20:43
BCs in an FSI simulation of a flexble pipe vivekcfd OpenFOAM 10 January 8, 2010 04:14
1-way FSI Vs. 2-way FSI k_buz Main CFD Forum 0 May 12, 2009 04:10
