-   ANSYS (http://www.cfd-online.com/Forums/ansys/)
-   -   post-processing (http://www.cfd-online.com/Forums/ansys/98250-post-processing.html)
Vitaly March 6, 2012 15:42
post-processing
What I want to do should be very easy, but I can't find a way to do it.
I have a specific surface with a WSS contour plot. All I want to do is output a txt file with the coordinates of each facet centroid and the WSS value at that facet.
Any advice?
Thanks,
Vitaly
murx March 8, 2012 07:18
If you are using CFD-Post, the way I would use is:
- insert a plane at the location where you are interested in the WSS values
- file --> export
- under Locations, select the Plane and select the variables on the bottom... which would be X,Y,Z, and the Wall Shear values you are interested in
Vitaly March 8, 2012 11:06
Thanks for the reply...
That is I have been doing, but I would like to be able to loop over a face in a UDF and get the values so that I could use them in the UDF.
Thanks,
Vitaly
