Geometry basics. How do i model an open domain to simulate a jet flow
Like Tree1Likes
  • 1 Post By scipy
Old   March 1, 2012, 10:52
Smile Geometry basics. How do i model an open domain to simulate a jet flow
Jan
canev.civelek is on a distinguished road
Hi there,
I am a new user to ANSYS and im struggling to create the geometry of a simple open domain. This will be the volume i will mesh to investigate a simple jet flow.
Ive tried doing a simple line diagram of the size and shape of the domain in the geometry section in workbench however when trying to open this in mesh states 'unable bodies found'.
I also tried making 2 faces (For the front and rear faces) and connecting them together however im still getting errors.
I know its just a simple setting or way to set this up however i cant find any iformation regarding this in the users guide.
Please let me know if you can help or where i may be able to get help from.
Thanks so much
canev.civelek is offline   Reply With Quote
Old   March 1, 2012, 12:09
krisshoe is on a distinguished road
Have you tried to use the extrude function? Draw a 2D sketch of one side of your box, and then extrude that sketch. You can specify the length of the extrusion.
krisshoe is offline   Reply With Quote
Old   March 1, 2012, 12:14
Jan
Hi there.
My first thought was to extrude it but then it will become a solid.
I am trying to create an open 3D or even 2D area where i can simulate a jet flow and view the behaviour.
Do you know if its possible to mesh a solid and then define it as open air during simulation?
Thanks.
Old   March 1, 2012, 12:33
You can change your body type from Solid to Fluid in the details of your body in Design Modeler. However, once you mesh your flow domain, you should be able to read it into FLuent, even if it is a solid body type. I'm certain I've done this before.
Old   March 1, 2012, 13:00
Jan
Can i change the body type into air?
Its a volume that i am meant to specify (Which is the domain) and simulate a air jet coming into this domain.
So its essentially air flow into air.
I just need to specify the volume to mesh.
I meshed a solid before however i was told this was not correct, that i cannot use a solid body. (I did try but couldnt work it out so thought he was right). Is he wrong?
Do you know how to change the solid body into an air domain?
Thanks for your input, its much appreciated.
Old   March 1, 2012, 18:14
Red face
scipy's Avatar
Alex Pasic
scipy is on a distinguished road
Send a message via Skype™ to scipy
I think a video I just made might help you a bit. It was aimed more at vehicle aerodynamics, but since it's just about creating an air domain it might be useful.
Part 1a: http://www.youtube.com/watch?v=dZR7Wi70Vec
Part 1b: http://www.youtube.com/watch?v=oFD9346U8zM
Meshing and other parts will be up tomorrow or at the latest by the weekend.
canev.civelek likes this.
scipy is offline   Reply With Quote
Old   March 12, 2012, 05:49
Jan
Hi Scipy,
The tutorials were extremely helpful. Thanks so much for the link. I know what you mean by there being lack of support for beginners.
Will you have any more tutorials coming out any time soon?
Thanks again
Old   March 12, 2012, 06:26
scipy's Avatar
Alex Pasic
Yes, I've just been busy this week. There are Fluent and CFD-Post tutorials in the making, as the video descriptions say.
Help: apply B.C. in my granular flow model ? Derek Jing FLUENT 1 January 8, 2020 22:38
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Yacht in Open Channel Flow andreimour FLUENT 1 October 15, 2010 00:54
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 09:17
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
