Home > Forums > ANSYS
ICEM bunching law exponential 1
Old   March 12, 2012, 07:04
Default ICEM bunching law exponential 1
Sascha
sasa120 is on a distinguished road
Hello everyone,
i want to analyse the influence of the mesh on the result. Therefor I created some meshes with different numbers of nodes.
For the O-Grid in the tube I want to keep the ratio constant and change the y+ value.
The Bunching law of the O-Grid is the Exponential 1 law. In the ICEM Help Engine I found the following equation to calculae the distance from the starting end to node i:
S_i = Sp1*i*exp(R*(i-1))
with
R= -log((N-1)*Sp1)/(N-2)
S_i is the distance from the starting end to node i,
Sp1 is Spacing 1,
N is the total number of nodes, and
R is the ratio
In my case N is 38 and SP_1 is 0.002mm.
So in my opinion S_38 should have the same value as the length of the edge wich is 22.5mm.
But when I calculate S_38 with the above-named equations the result is S_38 = 0.2429mm.
So what I wanted to do, is to change the total number of Nodes N and let the Ratio R constant. With these equations I wanted to calculate the new value for Sp1.
But there seems to be a mistake in these equation.
Can someone help?
Thanks in advance
sasa120 is offline   Reply With Quote
Old   March 21, 2012, 11:59
Rikio
rikio is on a distinguished road
Send a message via Skype™ to rikio
S_i is the length of the ith segment, i.e., from the segment's begining to end, rather than edge's begining to ith node.
rikio is offline   Reply With Quote
Thread Tools
Trackbacks are On
PEM Fuel cell module meshes. ICEM vs workbench aarvay FLUENT 22 January 26, 2016 00:47
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 01:27
ICEM Edge Params Bunching laws twsloss ANSYS Meshing & Geometry 4 July 14, 2014 08:43
[ANSYS Meshing] Workbench 13: Structured Hexa Meshes rooftop ANSYS Meshing & Geometry 18 May 13, 2014 03:57
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 04:39
