April 10, 2012, 04:27 |
Vertical axis wind turbine simulation
Vincent
hi there guys. I just started using Ansys and i have totally no idea what are the steps i need to take to run the simulation. My project is about simulating the Savonius wind turbine and the Darrieus wind turbine in order to compare their efficiency in terms of their angular velocity and torque generated under the influence of up to 6m/s wind speed. The simulation can either be done in 2D or 3D but 2D is preferable since it looks much simpler. Anyone has done such simulations before? Mind giving me some guildance? thousand thanks!
ansys12, cfd, fluent, wind turbine |
High torque coefficient Cm for Vertical Axis Wind Turbine (VAWT) | tony00 | FLUENT | 11 | July 23, 2018 06:13 |
Vertical axis wind turbine CFD Analysis | Akhilesh | FLUENT | 4 | April 13, 2012 16:44 |
3D simulation of wind turbine in Yaw wind(in a lateral wind) | mohammad | Main CFD Forum | 0 | December 28, 2010 03:26 |
wind turbine simulation problem | dennis0131 | Main CFD Forum | 4 | November 22, 2010 04:26 |
Advice on vertical axis turbine modelling | bramdiff | FLUENT | 0 | September 24, 2010 09:12 |
