Significant Reversed Flow at Outflow Problems [ANSYS FLUENT]
I'm running a closed domain cardiovascular simulation comprised of 2 mass flow inlet boundary conditions with 5 outflow boundary conditions. When the solution is calculated, the boundary conditions are held correctly but there is a huge amount of reversed flow happening at the boundaries. I have had the solution converge before to what looks like an appropriate flow field but I had to change a boundary condition and re-run the simulation. Now it isn't converging. I previously got the solution to converge by reducing the relaxation factors and starting with an initial velocity. Any ideas on how to eliminate reversed flow? Any help is appreciated. |
For those of you wondering, I think I may have solved my problem by initializing the solution using one of my inlets. As it turns out, initial conditions are important. :D
