Heat exchanger design
Old   April 14, 2012, 01:15
Default Heat exchanger design
libya81 is on a distinguished road
Hi there,
My project is to design two pipes one in side the other. I have drawed 4 skeches, one for the inner pipe, one for the inner pipe's wall, one for the outer pipe, and the last one for the outer pipe's wall. After that, I have created a surfaces for each one. Finally I have cut the first sketch by using a Boolean option and then subtract.
Do you guys think I am on the right track, or I have to create the fifth sketch, or I am totally designing a wrong geometry.
Best
Thanks in advance
libya81 is offline   Reply With Quote
Old   April 14, 2012, 10:03
Sixkillers is on a distinguished road
Hi!
I am not sure if it is precisely what you want, but the following tutorial you might find useful.
Sixkillers is offline   Reply With Quote
Old   April 16, 2012, 05:59
Andrea
Andrea1984 is on a distinguished road
I think the best way is first to create a volume which includes all your geometry (namely a cylinder of the same size of your outer pipe) and then splitting it using internal surfaces (to create all the internal domains you need).
I find out this is the best way to make fluent recognize well the interface surfaces between the different volumes.
Hope this can help
Andrea1984 is offline   Reply With Quote
Old   April 18, 2012, 04:39
唐磊
tanglei is on a distinguished road
hi
I think your operation is ok,
tanglei is offline   Reply With Quote
Heat exchanger design sakthi Main CFD Forum 6 September 3, 2022 01:22
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 02:21
HOW TO DESIGN AND SIMULATE HEAT EXCHANGER... fadly CFX 1 August 14, 2007 15:40
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
