Simluate smoke indoor (Smoke visibility).
hi~
I try to do the smoke visbility on Autodesk CFD simulatio, but i can't generate the smoke in CFD i follow the GuideLine, but it is still not success. Can anyone help me here ??? I created a house with two holes. One is on the side, One is on the ceiling. In the middle of the house there is a box where the fire generated. material Volume inside the the house is air. I set it to be variable. The wall of the house is brick. The box in the middle is made by hardwood. Boundary Condition Box: Scale = 1, Heat Generation = 2000W Air: Film Coefficient = 5 W/m2/K, Ref. Temp. = 19 Degree Hole on Ceiling: Volumetic Flow Rate = 50 L/s, Hole on Side : Pressure = 0Pa , Temperature = 20 Degree. Solve: Set Smoke Visibility on Heat Transfer on Specific Extinction Coefficient = 21000 The sign visibility constant characterizes = 3 combustion particulate yield = 0.08 Diffusion Cosfficient = 16 mm^2/s Solution : i set the output quantity is Scalar However, i cannot see the smoke in the CFD. Can Anyone help me I want to create the view like the one in the Guideline. Smoke visibility |
How can I simulate the fire of diesel for a smoke simulation in fluent?
HI did you got the method
Thanks |
Hello, I got a UDF from a video but I did not try it because the project was done by FDS. I can send the snapshot to you :)
Thanks |
Please, it will be great :)
1 Attachment(s)
Here you go :) Thanks
