[Sponsors] | |||||
JPConway
Rep Power: 3 ![]() |
playing around with the autodesk 360 trial.
specifically with the CFD portion. I can't for the life of me find a way to turn off the global plot. Is it possible? At some point I thought I was able to do it, but now I can't get back to that point and I didn't nab a screenshot to confirm that at some point I was able to do that. It may not be possible because I don't see anything in the help and all the screenshots I've seen show the global outlines. Note, I am able to get rid of the shaded view and am just stuck with the wireframe. Thanks. |
Ryan
What do you mean by 'global plot' -- the legend, or the coloring on the parts themselves? Both are possible:
Does this answer your question? |
JPConway
Hi Ryan, thanks for your response. I haven't had a chance to try your suggestions.
If I hide the legend, will that hide the legend for both the global plot and the plane plot that I'm trying to look at? Ideally I just want to get rid of the global plot legend. Regarding disabling the gradient, I have changed the visual style to outline and a specific color. But what I'd like to do is remove the outline completely. Is that possible? |
Ryan
If you hide the legend from the ribbon it will hide all legends, yes. To show a single legend, set the global result quantity to the same as your cut plane.
To hide a part completely, find it under the results > materials node of the design study tree and uncheck the box beside it. |
JPConway
Hi Ryan, is it possible to hide the outline of a component showing global results but keep the part showing the plane results? That is essentially what I'm looking to get.
Ryan
This is possible -- you will have to kind of fake it: set the part to transparent and then set the transparency to 100%.
JPConway
tricky. thanks.
i just wish you could control the visibility of global plots individually. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 7 | March 15, 2013 06:08 |
| Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
| Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
| IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
| Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
