[Sponsors] | |||||
Guido
Rep Power: 0 ![]() |
Hi there.
I'm about to install Autodesk Simulation CFD and I'd like to know if it is possible to calculate PCM (phase changing materials). If yes, how? I'd like to use it in the false ceiling and use this product: http://www.micronal.de/portal/load/f...09_English.pdf more info here: http://www.micronal.de/portal/basf/i...ursor=1_290814 basically it changes phase from solid to liquid when the temperature goes up to maintain the room temperature stable. Any hint/tip/link/help is highly appreciated. Thank you! Guido |
Mark Decker
Rep Power: 2 ![]() |
With some assumptions, you can approximate this by adjusting the specific heat Cp to vary in a piecewise linear fashion based on temperature. For example, water has a higher Cp for liquid state compared to solid ice state. At the transition point (0C) the Cp spikes above that of the solid Cp over a very narrow temp band. For temperatures outside this band, the Cp is set for the appropriate phase state.
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
| alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 14 | September 18, 2011 13:46 |
| Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
| mass flow in is not equal to mass flow out | saii | CFX | 2 | September 18, 2009 08:07 |
| compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
