Home > Forums > Software User Forums > Autodesk Simulation CFD
atmospheric and/or far field BC?
Old   January 23, 2013, 11:29
Default atmospheric and/or far field BC?
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
I am wondering whether Autodesk Simulation CFD has atmospheric BC and/or far field BC?
Thanks!
Pei-Ying
phsieh2005 is offline   Reply With Quote
Old   January 25, 2013, 12:53
Matt Brown
matt.brown.ae is on a distinguished road
We typically define the outer faces of the air volume to have the freestream velocity condition with a zero pressure outlet face. I am not sure what your application is, but that has worked for us in the past.
matt.brown.ae is offline   Reply With Quote
Old   January 25, 2013, 14:14
Pei-Ying Hsieh
Hi, Matt,
Thanks for the reply. I am quite new to Autodesk simulation CFD. May I ask how is free stream velocity defined? After selecting velocity, I do not see free stream that I can select. By free steam, do you mean 0 m/s, in the atmospherics case?
Pei-Ying
Old   January 25, 2013, 14:16
Mark Decker
marktm250xc is on a distinguished road
As Matt indicated, the far field downstream condition is typically a P=0. The drawback is that you need to extend the downstream domain enough to where a P=0 condition would exist so as to not artificially influence the area of interest.
I see that NX Flow 8.5 has added a new convective outflow condition where pressure does not have to be specified. This would allow the downstream domain to be much shorter ... their example shows it right behind a classic cylindrical vortex shedding simulation.
marktm250xc is offline   Reply With Quote
Old   January 25, 2013, 14:26
Matt Brown
The freestream condition really depends on what you are modeling. For example, say I wanted to model an airplane at 5 degrees angle of attack and 200 mph. To the forward face (inlet) and side faces of the air volume I would apply the following velocity BC's:
Vx=200*cos(5deg)
Vy=0
Vz=200*sin(5deg)
(This assumes that X points down stream, y points out the right wing and z is 'up'. aka air plane body axis)
I have also heard of people applying zero pressure not just to the rear face (outlet) but also to the side faces of the air volume. I have not personally tried this because I have had success setting these to the velocity BC's with only the outlet face as zero pressure.
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Is good initial guess field is neccessary ? mmkr825 OpenFOAM 5 October 17, 2012 12:58
Zero size field taranov OpenFOAM Bugs 2 April 20, 2010 04:51
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
