May 22, 2013, 09:09 |
conversion of geometry
Hi all.
I need to convert a solid exterior model to the inside fluid model, to prepare a CFD simulation. For an example this could be the geometry of a heat exchanger, which needed to be converted to the fluid model within the heat exchanger Does anybody know how to do this in autodesk inventor? Best Regards Thomas |
May 24, 2013, 09:15 |
Mark Decker
Rep Power: 13 |
Are you using Sim CFD (CFdesign)? Sim CFD, like other CFD tools, offers a "cap-and-go" process to automatically fill the voids when the model is launched into Sim CFD.
For example, take a length of pipe. In CAD, the solid pipe wall is modeled and you need the fluid volume. For this simple example, you could just extrude another solid. Or you could add a cylindrical disk to each end to "cap it" This create a watertight void which when launched into SimCFD, will become a volume which you can define as the fluid. The caveat is that is must be watertight. If the assembly contains gaps or holes or other "leaks", the autovolume will not be created. Although surfacing and other techniques can be used in CAD, the cap-n-go method is by far the most popular and easiest. |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
Reg difficulties in meshing the geometry...Urgent | arunraj | ANSYS Meshing & Geometry | 0 | August 26, 2011 23:25 |
2D geometry to 3D geometry | Sgonzalezg | ANSYS Meshing & Geometry | 11 | April 8, 2011 11:02 |
[ICEM] B-Spline, Faceted, kernel | Mario-CFD | ANSYS Meshing & Geometry | 1 | December 23, 2010 14:15 |
[snappyHexMesh] SnappyHexMesh meshes inside and outside of an STL geometry | villier | OpenFOAM Meshing & Mesh Conversion | 17 | June 15, 2010 19:51 |
