Home > Forums > Autodesk Simulation CFD
Boundary conditions for simulation of airflow over buildings
Old   October 29, 2013, 06:02
Default Boundary conditions for simulation of airflow over buildings
tkc
tkc01 is on a distinguished road
I am working on a simulation to find out the effect on changing the reflectivity on a roof surface under solar heating from the Sun. I have drawn up a model (cube) where the base is assume to the roof surface.
The height of the cube is 10m, which is my focus in finding the temp distribution up to 10m from the roof surface when I change the reflectivity of the roof surface.
I have define the left face as Velocity input and the right face as outflow.
The front,back and top sides I have defined it as symmetry.
However, I am stuck when it comes to the boundary conditions setting. I understand that I have to use the solar tracing model but for the other boundary conditions, what should I input?
tkc01 is offline   Reply With Quote
Old   November 22, 2013, 17:24
Apolo
ApoloV is on a distinguished road
You would want this model to be a multi part assembly (multiple volumes)
We would want to model the roof as a volume so that we can control its material properties. This would also allow for conduction through the roof to some film coefficient on the interior side of the roof to represent heat loss/gain to the rest of the building.
For the air volume, you may want to have it a bit larger than what you are after and then assign a temperature condition to the lateral sides, the top and the inlet where you have the velocity. The outlet would be a zero pressure without a thermal condition.
ApoloV is offline   Reply With Quote
Thread Tools
Trackbacks are On
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 13:58
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 July 15, 2005 04:15
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
