Home > Forums > Software User Forums > Autodesk Simulation CFD
2D-Simulation of airfoil
Old   March 21, 2014, 17:01
Default 2D-Simulation of airfoil
safe.payi is on a distinguished road
Hello everyone,
I am completly new to CFD and currently working on a project where I have to do a simulation of an 2D-Airfoil.
The following data is given:
Fluid: water
Fluid velocity: 4.5 m/s
Stationary and incompressible flow
Static Pressure: 3 bar
So for structered mesh, you have to consider the diffrent types of farfields, which effect the quality of mesh, but since Simulation CFD only supports unstructered mesh, I have chosen a simple rectangle as my farfield, with two more fields for denser mesh.
Since I am a novice in this field, I would like to ask you some Questions.
1) My first question is about the boundary conditions: I have set the right edge (inlet) to "velocity" (fluidspeed 4.5 m/s) and the outlet to "pressure" (3 bar gage). The other two edges are set to slip/symmetry. Are these BCs chosen correctly?
2) I am amazed but at the same time sceptical about the mesh generation. It seems really easy to generate a unstructured mesh but at the same time I can't estimate its quality. Seeing the results, my generated mesh seems to do a good job. Could one of you take a look at my mesh and results? So far, I have mostly seen hexa-meshs for 2D-simulations, but can a tetra-mesh be that accurat too?
3) How can I make a cp-plot (pressure coefficient along both surfaces (pressure and suction side)). I have an excel-file with points of interest for measuring. Is there a possibilty to import these points?
4) My last question for now: Autodesk Simulation CFD chooses the Standard k-ε turbulence model by default. I don't know where I can change this but is this model suitable for my task?
I know these are quite some questions, but I would really appreciate it if you guys could help me here.
Many Thanks and Best Regards
safe.payi
PS: Here is the result file
safe.payi is offline   Reply With Quote
Old   April 27, 2014, 15:50
surry99 is on a distinguished road
Have you moved or deleted you result file?
Regards
surry99 is offline   Reply With Quote
Old   June 9, 2014, 10:28
Apolo
ApoloV is on a distinguished road
This has been covered decently in the SimCFD forums on the Autodesk page.
There was another person that went through a lot of this on a 2D airfoil where I believe the only difference was that theirs was in Air not water.
As far as Turbulence models this is changed under the Solve dialog / Physics / Turbulence button.
And discussed in the online Help
ApoloV is offline   Reply With Quote
Domain format problem on airfoil flow simulation andrenonaka CFX 14 December 7, 2015 00:42
Airfoil simulation using moving wall Alejandro Fidelity CFD 9 November 4, 2008 02:00
NO STAGNATION POINT FOR AIRFOIL SIMULATION Rif Main CFD Forum 6 February 4, 2008 07:33
Simulation of transonic flow over NACA0012 airfoil MSc Student Siemens 2 August 9, 2006 13:49
Compressible transonic airfoil RAE2822 simulation Stefano Siemens 9 June 21, 2006 10:47
