September 19, 2014, 17:52 |
Transient Volume Flow through a Plane
Arizona
Hello! I'm new to here and to CFD in general, I'm looking to learn allot. I'm currently a second year engineering student in Arizona, and I'm doing this for fun and experience with the student licenses.
I have a model of a centrifugal water pump and impeller, and I'm trying to get the program to output a graph or a chart of the volume flow through a plane positioned at the outlet. The impeller part is rotating from 0 rpm at an acceleration of 5000rpm/s, and the boundary conditions (temperature and pressure) are steady state for the inlet and outlet. I don't knew if this changes anything, but both my inlet and outlet faces are identified as outlets in the output monitor. I ran the simulation partway through to see if everything was working right, and was able to take out most the data I was expecting, but now I'm completely stuck. I would appreciate either a push in the right direction or a tutorial of some sort. Is there any other information you guys need from me? Thanks! |
Display Modes | |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
InterFoam channel Flow runnig very slowly | Wokl | OpenFOAM Running, Solving & CFD | 4 | January 9, 2014 03:52 |
Laminar gas flow under slight suction - transient works but not steady | audrey | CFX | 1 | September 8, 2011 20:43 |
How to change from mass flow to volume flow rate | stanley | FLUENT | 1 | February 2, 2007 07:44 |
Flow + split volume | Mark | FLUENT | 3 | March 18, 2003 11:09 |
